Date/Time: Sun, 19 May 2024 14:15:10 +0000
developer command line tools support in SC?
View Count: 559
[2019-09-06 13:24:23] |
jseppa - Posts: 18 |
Hi, I'm currently using cl.exe to build. In order to release the DLL whilst developing, I'm using the options in the "Build Advanced Custom Studies DLL" window (Release/Allow) Is there a way developers can do these tasks via command line to speed up the process? I'd like to add it to my cl.exe compile script. Cheers, Jason |
[2019-09-06 13:38:00] |
User907968 - Posts: 804 |
Is this any help? Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code I use a script to communicate via UDP interface. |
[2019-09-06 13:53:08] |
Spot on mate. Cheers
