Date/Time: Sun, 19 May 2024 16:36:09 +0000
match $TICK to Volume based chart
View Count: 647
[2019-09-06 08:29:41] |
AKR - Posts: 523 |
Is there a way to create a $Tick chart based on the ES Volume. So question is is it possible to get the TICK in a eg 1000 Volume ES chart that matches? What volume is taken when I have just the TICK chart and set it to 1000 Volume? |
[2019-09-06 15:26:57] |
Yes this can be accomplished with this particular study: Add Additional Symbol But we have discovered a recent problem related to the volume data for the chart bars for the main price graph when using this study. We will have a new version out in about an hour which corrects this. What volume is taken when I have just the TICK chart and set it to 1000 Volume? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-06 15:30:30
[2019-09-09 11:19:42] |
AKR - Posts: 523 |
awesome !!
