Date/Time: Sun, 19 May 2024 14:54:35 +0000
True Millisecond Time Stamping FX Data
View Count: 520
[2019-09-06 05:37:48] |
User106180 - Posts: 88 |
I understand that true millisecond time stamping is available for trade and market depth data for the SC Exchange Data Feeds. From inspecting the FX intraday data files it does not appear to have true millisecond time stamping. Will you be introducing this for FX data? This may not be possible as it appears as though the FX data comes from FXCM. If that is the case does the LMAX data feed offer true millisecond time stamping? Thank you. |
[2019-09-06 15:41:57] |
True millisecond time stamping for trades, is coming. This is not yet available. Only for market depth data.
