Date/Time: Sun, 19 May 2024 12:52:57 +0000
CQG Fast update
View Count: 616
[2019-09-05 22:25:51] |
User619571 - Posts: 6 |
I was doing the update, nothing happened the massage log is still up with the last line states Triggering next historical data download in queue. It has been stuck here for the past 15 minutes. Thanks for the help |
[2019-09-06 11:23:38] |
Just run the Sierra Chart installer from this page to update your installation of Sierra Chart: Software Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
