Date/Time: Sun, 19 May 2024 15:10:04 +0000
In real time, Add Additional Symbol impacts volume under some conditions... ?
View Count: 570
[2019-09-05 20:08:36] |
wwwingman - Posts: 185 |
Hi When using the Add Additional symbol of AAPL to an NQ chart, the volume of NQ behaves in an unexpected manner. It increases a lot more than then real traded volume. Here is a simple way to reproduce the problem, in real time. 1. Creat a chartbook with 1 5mn chart of @NQ# (IQFeed). 2. Add volume study. All works ok. 3. Add additional symbol. Set to AAPL. 4. watch @NQ# volume increasing quickly to abnormal values. If you refresh the chart it will go back to the normal values, and start increasing again abnormally. Here is an screenshot example : http://www.sierrachart.com/image.php?Image=1567713684545.png Enclosed-by a chartbook for testing. This is particularly visible during stock market hours (have not tested overnight). Please advise. -- W |
VolumeGettingCrazy.Cht - Attached On 2019-09-05 20:05:58 UTC - Size: 39.76 KB - 233 views |
[2019-09-06 11:10:39] |
We are looking into this now. This will be resolved in the next release.
[2019-09-06 16:00:46] |
We will have a new release out in about an hour.
