Date/Time: Sun, 19 May 2024 16:36:12 +0000
Width
View Count: 577
[2019-09-05 18:49:27] |
John Ara - Posts: 125 |
Please let me know how to set width of columns showing numbers bars without affecting vertical scale? Thank you. |
[2019-09-06 18:10:17] |
In order to not have the vertical scale change with the bars, you need to set the scale to User Defined and then just change the horizontal scaling using your preferred method (Page Up/Page Down, Control Bar Buttons, etc.). Refer to the following: Chart Scale and Scale Adjusting: User Defined (Scale Range) and to the following: Working With Charts: Changing Bar Spacing Also, be aware of the Constant Range scale option, in which you can define when the scale should move: Chart Scale and Scale Adjusting: Constant Range (Scale Range) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
