Date/Time: Sun, 19 May 2024 14:15:02 +0000
[User Discussion] - Sever delays to price data updates, when market opens
View Count: 480
[2019-09-05 18:27:02] |
David Clarke - Posts: 23 |
Hi Over the last week I have noticed that immediately after the market opens (09.30 EST), I suffer significant delays to my pricing feed, often for up to an hour. I try disconnecting and re-connecting the feed, but this has little effect. I am using Version: 1983 32-bit (28337m), which I believe is the latest. I have excellent broadband connectivity of 218Mb/s and have a wired connection to the router, not wi-fi. I am, however, based in the UK and wonder if this has any bearing on this. Can you please advise. |
[2019-09-05 18:34:42] |
Your Sierra Chart account is expired. You need to log into this support board with Help >> Support Board to make sure you are using the correct account. When that is done post here again.
