Date/Time: Sun, 19 May 2024 12:53:10 +0000
[User Discussion] - Downloaded data files differ after redownloading
View Count: 473
[2019-09-05 17:59:59] |
User629079 - Posts: 1 |
Hello :-) I noticed that if: I delete data files for e.g. cacao futures (F.US.CCEN16.scid, ...) and download it, delete it and download it again then these two times downloaded files(e.g.: F.US.CCEN16.scid) are different. But these contracts are not traded any more. So these files should be exactly the same. When I compare these files I see difference in many single bytes. What do I do wrong? Why these files are different every download? Which one are correct? (I use SierraChart 1983 and CQG data feed) Regards :-) |
CCEN16.zip - Attached On 2019-09-05 17:28:52 UTC - Size: 1.6 MB - 251 views Attachment Deleted. |
