Date/Time: Sun, 19 May 2024 13:08:32 +0000
Cannot open orders on Bitmex
View Count: 842
[2019-09-05 17:46:41] |
User613558 - Posts: 1 |
Hello, Every time i wanted to open an order on Bitmex, the log gave me this: New order rejected - BitMEX Trading Direct error: Unsupported execInst. Internal Order ID: 210. Service Order ID: (none). Symbol: XBTUSD-BMEX. Account: 158046 | 2019-09-05 19:42:53.904 * What is this, and how to resolve it? Thanks in advance for your answer |
[2019-09-05 19:04:35] |
Refer to this section here regarding execution instructions: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SettingOrderExecutionInstructions If you have any manually set instructions, remove those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
