Date/Time: Sun, 24 Nov 2024 21:48:20 +0000
tick size tpo value area lines
View Count: 1183
[2013-12-10 20:48:31] |
jim branch - Posts: 23 |
When using TPOvalue area lines with the s&P 500 futures charts, should the tick setting be set at .25 or .01?
[2013-12-10 20:59:06] |
.25
