Date/Time: Sun, 19 May 2024 13:38:55 +0000
left side scale range
View Count: 1156
[2019-09-05 15:54:52] |
User503358 - Posts: 50 |
I have 4 chart studies on the same chart region 1 with the same user defined range. only first one is connected with left side scale range, other 3 are connected with right side scale range and move with right side control. How to reconnect this 3 studies to the left scale range to control all 4 studies simultaneously?
[2019-09-05 18:05:17] |
You cannot do this. The left-side scale only applies to one study. All the other studies are going to be dependent on the right-side scale. Refer to the documentation for the left-side scale here: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) You need to uncheck the option Use Left Side Scale. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
