Date/Time: Sun, 19 May 2024 09:47:27 +0000
How can I calculate the derivative of a Line?
View Count: 642
[2019-09-05 15:32:19] |
User452567 - Posts: 38 |
How can I calculate the derivative of a Line? Thank you |
[2019-09-10 09:06:32] |
There is no built-in tool to do this. Since the first derivative is just the slope of the line tangent to the point, you could estimate this as the slope of the line between two points. The result would be the slope at the middle of the two points. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
