Date/Time: Sat, 19 Sep 2026 08:52:00 +0000
Changing Days of Loaded Data Programmatically
View Count: 1443
[2013-12-10 20:09:18]
Bad Dog - Posts: 17
Is there a way to change the number of days of loaded data using ACSIL?
I want to load a new symbol using sc.DataFile, but I also want to change the bar time period and the number days of loaded data at the same time.
-BD
[2013-12-11 18:04:24]
vegasfoster - Posts: 444
I would like this feature too, this way when you change the bar size then you could automatically change the number of days to load as well, e.g. 4 range would load 5 days, but 20 range would load 90 days. :)
[2013-12-11 18:46:36]
N2S - Posts: 15
+1
[2014-12-03 17:42:57]
Halir - Posts: 2
+1
[2014-12-03 21:39:21]
We will add this capability.
[2014-12-06 01:54:12]
This has been added and it will be out in the next release.
sc.DaysToLoadInChart
Date Time Of Last Edit: 2014-12-06 01:54:29
