Date/Time: Sun, 20 Sep 2026 00:56:51 +0000
Calculate the area between 2 lines. The integral.
View Count: 1055
| [2019-09-05 15:07:25] |
| User452567 - Posts: 38 |
How can I calculate the integral (area) between 2 lines? Thank you |
| [2019-09-06 19:06:14] |
There is no built-in method to perform a true integral, in which you would find the area between the lines over the entire x-coordinate system. This is because the chart bars are quantums, therefore most (maybe even all) studies deal with the data from bar to bar and do not deal with the space between them. But, if you want to find the area between the lines based on the bar data, then use the Study Subgraph Subtract study to get your difference at each bar, then use the Cumulative Sum of Study to sum up those results. Refer to the following for the Study Subgraph Subtract study: Study Subgraph Subtract Refer to the following for the Cumulative Sum of Study study: Cumulative Sum of Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
