Date/Time: Sun, 19 May 2024 14:54:34 +0000
OCO 1 by 1
View Count: 565
[2019-09-05 09:30:52] |
User266069 - Posts: 30 |
Hi, I enter 3 contracts at a time. And after my entry I'd like to set my stop & target OCO 1x1x1. Within "Targets" tab I set quantity to 1. Ive set a hotkey for "Send attached orders - position" Sometimes it gives me 1x1x1, sometimes it gives me x3 that I can't split. How can I force it to do 1x1x1? Thank you. |
[2019-09-07 07:03:04] |
We are not understanding this.
