Date/Time: Sun, 19 May 2024 14:46:23 +0000
ColorBar on Alert not Triggered
View Count: 555
[2019-09-05 05:30:50] |
User312841 - Posts: 25 |
Stuck on a problem where the behavior does not appear to match the code. Using colorBar on alert with simple moving averages. If Fast>Medium>Slow color bar deep blue. Here is the code -> =AND(ID1.SG1>ID2.SG1,ID2.SG1>ID3.SG1). In the attachment the 3 MA's lined up but the colorBar did not paint, green arrow is pointing to it. I have the same code in the spreadsheet to trigger a trade and it executed when the MA's lined up. I have tried everything I could think of with no luck. Thanks
SPXL-STK-SMART 0.05 Range #2 2019-09-05 01_16_31.578.png / V - Attached On 2019-09-05 05:18:32 UTC - Size: 33.55 KB - 249 views |
[2019-09-05 05:54:43] |
Could be due to what is explained here: Study/Chart Alerts And Scanning: The Effect of the Value Format on Identifier Values (The Effect of the Value Format on Identifier Values) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-05 05:54:58
