Date/Time: Sun, 19 May 2024 13:39:04 +0000
update from v1400?
View Count: 469
[2019-09-04 21:31:00] |
User22396 - Posts: 191 |
Hello support- I have been away from the software for about 3 years and wanted to update to newest version. Should I be concerned that some spreadsheet studies or custom indicators may not work with newest versions? Thanks |
[2019-09-04 23:41:50] |
We would not expect any problem with Spreadsheet studies but testing is important to verify there are no changes needed. Potentially some custom studies will need to be recompiled. That you should expect would be necessary. But that is all you should need to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
