Date/Time: Sun, 19 May 2024 14:15:02 +0000
Symbols for the $ADD and $TICK
View Count: 1762
[2019-09-04 18:46:29] |
tommartin321 - Posts: 74 |
Hello, I just switched over from IQFeed to SC Data - All Services and I'm trying to figure out the symbols for the $ADD and $TICK. For starters, I'm not sure if I should be choosing from Indexes, or Market Stats. Thanks, Tom |
[2019-09-05 01:34:12] |
The symbols are as follows: NISS-NYSE TICK-NYSE They are listed under the Market Stats. Refer to: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-05 01:34:28
