Date/Time: Sun, 02 Feb 2025 12:49:35 +0000
[User Discussion] - Highlight resting orders on DOM over a certain value?
View Count: 628
[2019-09-04 15:12:38] |
User339484 - Posts: 71 |
Is there a way , similar to the heat map, to highlight resting order over a certain amount on the DOM itself? This can kind of be done by adding the heatmap study, but it doesn't work as well. Thanks! |
[2019-09-11 18:23:43] |
Basically what I am looking for is a way to highlight a quantity on the DOM if it is over a certain value.
