Date/Time: Sun, 19 May 2024 15:10:07 +0000
CQG data
View Count: 914
[2019-09-04 13:45:19] |
User907846 - Posts: 1 |
Hi I was wondering if I can get real time CQG data added onto my SC5 package?
[2019-09-05 01:00:10] |
The CQG Trading platform service is supported. But you will need to obtain the CQG service, from your broker. If you already have a broker that supports CQG, or once you get setup with one, then just follow the setup instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-05 01:01:07
