Date/Time: Thu, 02 May 2024 23:53:45 +0000
[Programming Help] - Bitmex 3x daily funding causes position state error
View Count: 622
[2019-09-02 18:35:43] |
User947264 - Posts: 2 |
Example: 1) Long position opened 2) 1 of the 3x daily funding events occurs. If any open position is held at 04:00, 12:00, or 20:00 GMT, Funding is either received or paid 3) SierraChart interprets this as a position being closed 4) Future orders to Close Long is interpreted as the opening of a Short. All subsequent trades are now off by one, where closing positions is actually associated with the opening of a new position. Is there a way to handle Bitmex funding within SC? I've been unable to find documentation about this issue. Date Time Of Last Edit: 2019-09-02 21:14:30
[2019-09-16 18:13:18] |
User218474 - Posts: 8 |
Wanted to follow up here due to lack of documentation. Could SC Engineering offer any insights on this issue?
[2019-09-17 11:45:54] |
It sounds like you are reporting a problem with the Trade Position Quantity not being reported correctly when using BitMex. If so, refer to: Trading Information Windows: Incorrectly Reported Trade Position Quantity There is nothing special Sierra Chart needs to do in relation to funding. BitMex needs to report the Positions correctly. It is straightforward and simple like that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-17 11:47:41
