Date/Time: Thu, 02 May 2024 16:19:52 +0000
ACSIL, calculation precedence and order of calculation possible issue
View Count: 1217
[2019-09-02 18:46:37] |
onnb - Posts: 661 |
I have a study that references two other studies as inputs All studies have Standard Precedence I expected my study to be calculated after the two it references. I am seeing that it correctly calculates my study after one of them, but not the other (the 2nd referenced study is calculated after mine) |
[2019-09-02 18:48:41] |
onnb - Posts: 661 |
As a workaround, we made a change in the calculation precedence of our study and it works ok. But we still expect that with the standard precedence it should have worked. |
[2019-09-03 03:35:38] |
For complete documentation in regards to this, refer to: Chart Studies: Study Calculation Precedence And Related Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-17 01:36:38] |
onnb - Posts: 661 |
I am somewhat familiar with the above link (not first time I am seeing it). I reviewed it once more just now and it still does not make sense. Chart Studies: Study Calculation Precedence And Related Issues Referring to the documentation, I "think" the issue is related to *[3] where you have multiple input references in one study. The scenario I am looking at looks like this (all study precedence levels are "STD_PREC_LEVEL") Study1 Study2 is based on study1 Study3 Study4 is based on study3 Study5 references study2 and study4 via inputs The calculation order I get is: Study1 Study2 Study5 Study3 Study4 I can a simple example that demonstrates it. Date Time Of Last Edit: 2019-09-17 01:37:00
