Date/Time: Sun, 02 Feb 2025 09:58:23 +0000
vertical control bar
View Count: 722
[2019-09-02 14:47:24] |
User972583 - Posts: 3 |
is it possible to rotate control bar to vertical rather than horizontal?
[2019-09-03 04:20:37] |
Yes. Refer to: Control Bar: Moving and Detaching the Control Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
