Date/Time: Sun, 02 Feb 2025 09:56:50 +0000
How do I set intra day relative volume on sierra chart
View Count: 1767
[2019-09-02 14:04:10] |
User627233 - Posts: 3 |
How do I set this on sierra chart? Each period = 3 mins, Relative volume = Total volume traded in each period / Rolling Simple Moving Average (30 period or 90 mins) of volume traded |
[2019-09-02 14:05:11] |
Can I upload my trading strategy in Python which uses a library called "rolling" (pip install rolling) on sierra chart? Thank you!
[2019-09-03 04:18:09] |
Have a look at this study: Relative Volume You can also set the chart bars to 3 minutes per bar and base a Moving Average study with Length of 30 on Volume: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study The answer to post #2 is no. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-03 04:18:36
