Date/Time: Sun, 02 Feb 2025 21:41:58 +0000
Cannot connect to Transact Trading service. URGENT.
View Count: 739
[2019-09-02 06:46:55] |
User800328 - Posts: 50 |
Hi, I no longer can connect to Transact. Please note that I can successfully login into their AT platform. So, it means my username and pwd is correct. (In fact I called up Transact and they are saying everything is fine from their end.) Here is the error I am getting. http://www.sierrachart.com/image.php?Image=1567371519698.png Please resolve it asap. Thanks. |
[2019-09-02 10:32:45] |
I think it started working after few hours automatically. Thanks. |
[2019-09-02 10:35:53] |
They must have resolved this. And only Transact can resolve this. We cannot. The best we can do is tell them about the problem directly ourselves.
[2019-10-15 11:13:14] |
amirN - Posts: 159 |
Hi, I'm having simmilar problem as the above. Has this been sorted in SC now.
[2019-10-15 11:32:10] |
Refer to: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
