Date/Time: Sat, 27 Apr 2024 19:54:27 +0000
Range Bar issue(must read)
View Count: 493
[2019-09-02 05:25:17] |
User392279 - Posts: 67 |
Hi, when I select Range bar(fill gap) I find it also fills the gap between sessions. This caused miscalculation like opening price and VWAP line etc. studies. Please resolve issue asap. Range bar(fill gap) is my favorite bar type. Thank you! |
2019-09-02_131745.png / V - Attached On 2019-09-02 05:21:14 UTC - Size: 345.79 KB - 246 views |
[2019-09-02 11:12:58] |
There are not going to be any changes to that type of Range bar setting. That you can be assured of. Have a look at using this setting instead: Chart Settings: Intraday Chart Bar Period >> Gap Fill (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-02 12:53:02] |
the GAP Still filled even fill gap set to 'none'. Issue still.
