Date/Time: Sun, 28 Apr 2024 10:18:07 +0000
[User Discussion] - Options on Futures not available
View Count: 533
[2019-09-02 01:44:02] |
joemarc - Posts: 11 |
Using the find symbol menu under the file menu I have been able to download options chain on futures without issue. Today I noticed that this function is not working, the download button in the dialog box shows up as usual but clicking on it does nothing. Any idea on how to fix this issue. Thanks |
[2019-09-02 04:53:01] |
We will check on this and test. For what symbol did you try to get options for?
[2019-09-02 14:44:02] |
The symbols (futures) ES, ZN, GE Thanks |
