Date/Time: Tue, 15 Sep 2026 04:15:16 +0000
[User Discussion] - Help request: recording market depth
View Count: 1389
[2019-09-01 21:44:13]
ticinotrader - Posts: 429
Dear Support,
Can you please advise on how to adjust the Market Depth Data recording related settings? I have just checked both my specific symbol related and global symbol settings in SC and I found that recording of the depth data is turned off by default on symbols that I have been selected and able to record previously - probably after I upgraded to a newer version.
Also can you please let me know how to adjust the setting 'Record Market Depth Data' in the symbol settings? It is set to 'No' by default - I can change it to 'Yes' as a custom setting, but haven't found the section that controls the default setting to turn symbols 'on' by default.
I have already manually set all my symbols to 'Custom - Yes' some versions earlier, but it reverted back to 'No' during the last week leading to no recorded depth data on the ~30 markets I follow.
I use SC realtime datafeed.
Thanks for your advice in advance.
[2019-09-03 04:22:54]
In regards to this, refer to the notes for version 1953:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1953
There is no way to set a default for symbol settings. You can only change individual settings for individual symbols.
[2021-03-06 14:05:08]
GravisHTG - Posts: 321
I am trading Stock , And I would like to do some trading replays to test if I like the new market depth indicator I put on my chart.
Now , I don't have level 2 , but At least I have the last known bid ask , and in live trading It shows on my chart with market depth study.
But it does not show on the market reaply , it only shows on live data , Is that because I did not enable the record market depth data or something else?
And If so , How can I enable it for all Symbols or do i really have to do it one by one ? As with my trading strategy, I have 100 to 500 symbol to follow during the course of 1 year.
And another thing, I cannot find my symbol in the Global Settings >> Symbol Settings. Is the symbol in picture are the one I should edit ?
Thanks.
Date Time Of Last Edit: 2021-03-06 17:53:31
imagesymbol settings.PNG / V - Attached On 2021-03-06 14:12:42 UTC - Size: 10.22 KB - 363 views
imagesecond picture.PNG / V - Attached On 2021-03-06 17:34:15 UTC - Size: 4.3 KB - 333 views
