Date/Time: Sun, 19 May 2024 16:09:20 +0000
Attached Order with only a Stop?
View Count: 583
[2019-09-01 18:35:36] |
User590330 - Posts: 1 |
I feel a bit like a crazy person and I'm there must be an easy answer but is it possible to setup an attached order with only a stop? I have read all the documentation and it doesn't seem to be a possibility. All the documentation I could find/google seems to show only bracket orders. Is it possible to have just an attached Stop and no Target order? |
[2019-09-02 04:50:18] |
Yes this is fully supported. Just simply remove the Target order from the list of Attached Orders: Attached Orders: Step-By-Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
