Date/Time: Sun, 19 May 2024 15:10:01 +0000
Hand dragging function not working
View Count: 590
[2019-09-01 16:39:08] |
User636141 - Posts: 13 |
I can drag chart side to side but not up and down (vertically). Please advise. Thank you guys! Arjuna |
[2019-09-02 04:57:17] |
This is explained here in the documentation for the Hand tool: Chart Drawing Tools: Hand There is an option you need to enable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
