Date/Time: Sat, 27 Apr 2024 14:17:43 +0000
Number bars tick data
View Count: 517
[2019-09-01 12:37:24] |
User740266 - Posts: 26 |
The tick data forming the number bars are in the form of tick by tick data or snapshot tick data? Thanks.
[2019-09-02 05:07:04] |
This depends upon the data feed you are using Sierra Chart with.
[2019-09-02 05:11:33] |
What about if I use Sierra Chart - All services for glx cme nymex and comex futures markets? |
[2019-09-02 12:20:57] |
The Sierra Chart provided data feeds do provide tick by tick data, which means Numbers Bars will be based on that data.
