Date/Time: Fri, 11 Sep 2026 10:52:39 +0000
Bug in auto retracement/projection indicator?
View Count: 1180
| [2019-08-31 19:14:29] |
| Freshie - Posts: 5 |
Hi, was experimenting with this. It seems to work well when using 1,2 and 4 days as input in "time period unit length" and "number of days to calculate". However there is a problem when you key in 3 days? The values come out all weird and the chart screen seems shifted to extreme top for NG... like this https://gyazo.com/d8b9decf0f09fe9cbb0158477cb16b05 why? Same problem when you key in 5 and 6 days as input... but 1, 2, 4 and 7 works fine. Why does substituting with those numbers cause this rendering problem? Wish this could be fixed so I could save time manually drawing everyday. Thanks! |
| [2019-09-02 12:34:21] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image We also need to get that particular chart and its study settings by following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
