Date/Time: Wed, 12 Mar 2025 17:04:10 +0000
divide or multiply the price ?
View Count: 1943
[2013-12-10 12:58:28] |
yoytu - Posts: 59 |
is there anyway to divide the price chart for a set value ? is there any way to divide the gold by silver to get the gold silver ratio ? example for gold silver ratio: http://i.imgur.com/zI8YKEB.png |
[2013-12-10 15:50:11] |
1. You can use Study Subgraph Divide to divide the price by a set value: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s281 2. To get the ratio you will need to use the Ratio study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s5 To add a study to a chart, refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart Sierra Chart Support Date Time Of Last Edit: 2013-12-10 16:23:37
[2013-12-10 19:47:05] |
You can divide or multiply the price data by using the Price Multipliers in Chart >> Chart Settings >> Advanced Settings 2
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-10 19:47:18
[2013-12-16 00:44:18] |
yoytu - Posts: 59 |
You can divide or multiply the price data by using the Price Multipliers in Chart >> Chart Settings >> Advanced Settings 2 and how u divide the prices from CNY to get the usd ? u cant type 6,07 |
[2013-12-16 00:49:02] |
A simple example would be if you want to divide prices by 10, you would multiply by .1. So you would calculate 1/divisor and then use that as the multiplier. And you can also manually type in any value for the Multipliers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-16 00:49:43
[2022-05-19 15:59:10] |
User840539 - Posts: 25 |
For some reason multiplication does not work in new chart settings. The 'Tick Size' multiplication is not working while dividing works just fine. By typing '/' it's possible to divide, but typing '*' is not functional. Maybe another symbol is used for multiplication?
Date Time Of Last Edit: 2022-05-19 15:59:31
[2022-05-19 16:09:42] |
John - SC Support - Posts: 38612 |
What setting are you trying to enter information for and how are you trying to enter it?
[2022-05-19 16:14:33] |
I'm changing the Tick Size in Chart settings. Next to let's say 0.10000 I type either '/2' or '*2'. Only division works.
[2022-05-19 16:30:22] |
You should only be entering numbers in that field. If you want a tick size of half of 0.100 then you would need to enter 0.0500.
[2022-05-19 16:37:30] |
It was discovered by accident though. If according to you only numbers should be entered, then typing "0.1000/2" and getting an output of "0.0500" is an error I suppose.
[2022-05-19 16:43:39] |
We are very surprised it worked. It is just a lucky thing that it did. In general, though, you should not be entering values that way. Just enter the actual value you want.
