Date/Time: Tue, 22 Apr 2025 02:24:39 +0000
[User Discussion] - Study Summary Window Rows and Columns
View Count: 915
[2019-08-31 12:34:28] |
ILIM KIRGIZ - Posts: 187 |
Dear Support, I decorrelate FX Pairs and then measure against each other to be able to find currencies against each other. I watch the market overview via study summary. See attached. I need to have this graph vertical, not horizontal, as charts are occupying rows entirely but I need them to be on columns. Is there any setting or chance to achieve this? The current structure requires me to create an additional 28 charts to achieve this. Thanks. |
[2019-09-02 12:47:06] |
You are asking for something that is just not supported and is never going to happen and we have nothing further to say. It will not help to ask further about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-02 12:47:25
[2022-01-11 19:14:24] |
User379468 - Posts: 508 |
How is this set up to show an alert condition for multiple timeframes for each instrument this way in study summary window?
[2025-02-07 03:05:41] |
User624595 - Posts: 243 |
How can alert conditions for multiple timeframes per symbol be shown in study summary window, without needing a separate chartbook/study summary window for each timeframe? |
[2025-02-07 15:37:17] |
The Study Summary window shows charts that have studies on them along with the subgraph information for those studies. Therefore, charts with different timeframes will show as different charts in the list with their respective studies showing. An alert on one timeframe will then show for that chart and study. Refer to the following: Study Summary Window: Setting Alerts and Alert Highlighting For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
