Date/Time: Sun, 19 May 2024 21:31:19 +0000
Commission Cost
View Count: 1411
[2019-08-31 00:34:58] |
User94606 - Posts: 327 |
How can i include commision cost to the trade P/L. I thought there was a global setting but I cannot find it.
[2019-08-31 06:17:31] |
It depends where you mean. Refer to: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Trade Activity Log: Use Commission Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
