Date/Time: Tue, 04 Nov 2025 09:19:33 +0000
custom study
View Count: 740
|   [2019-08-30 20:51:50]     |
| Devil_On_WallStreet - Posts: 67 |
                Is it possible to get access to some of your study codes not included in the studies.cpps? I know you don't include certain codes because of the swarm of questions that would come. The 1 I most want access to is the Market Depth Historical Graph. I really want to change the way it calculates the "100%' for based on percent or "Highest level" for based on Actual. Plus VERY interested in seeing how it graphs everything without using/setting all of the individual subgraphs. Every study in my chartbooks has been customized in some way to fit my needs and would very much appreciate being able to get access to the codes for the other studies. I am debating releasing all of my custom studies to the public, but need to finish them all I'm also happy to share the code with you after I am finished. Will probably just add an option to calculate the 100%/max from Session's Highest Bid/Ask Date Time Of Last Edit: 2019-08-31 03:29:07
|   [2019-09-02 12:58:13]     |
                There are many reasons why the code for some studies are not available to the public, but one of the main ones is that the code is embedded into the core program, as the way it performs, and the information it needs, is not available through the ACSIL interface, nor can it be. It simply cannot be created as a standalone DLL like other studies can. Or at least, not in a way that would perform at any reasonable level. Therefore, we are sorry, but this is not available. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2019-09-03 00:27:11]     |
                Hopefully in the future you will add the option to have the Market Depth Historical Graph calculate the "Maximum Quantity for Coloring" Based off of the Highest Bid/Ask Quantity of the session
|   [2019-09-03 01:48:19]     |
                We will see about this.
