Date/Time: Mon, 10 Mar 2025 00:55:06 +0000
Footprints
View Count: 1485
[2019-08-30 20:50:57]
User491299 - Posts: 26
Good day. I have a question how I can highlight diagonal percentage imbalance for example If diagonal imbalance is more then 300% I want to color it in red. And not changing my background coloring method. thank you https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=31112
[2019-08-30 21:43:01]
John - SC Support - Posts: 38516
The following study collection will give you the idea of how to do this and should give you enough information to modify it for your specific needs:
https://www.sierrachart.com/AdditionalFiles/NumbersBars4xImbalanceHighlight.StdyCollct
In this particular Study Collection, the Numbers are highlighted if there is a 400% imbalance, but it is just for a direct comparison, not a diagonal comparison. You would need to change the Text Coloring Method to Based on Diagonal Dominant Side AskVol BidVol Percentage.
Refer to the following instructions how to use a Study Collection:
How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection
[2019-09-03 03:25:04]
Also refer to:
Numbers Bars: Diagonal Comparison of Bid Volume and Ask Volume
