Date/Time: Sat, 27 Apr 2024 21:57:58 +0000
TransAct Account + Sierra Chart
View Count: 691
[2019-08-30 18:44:02] |
User979626 - Posts: 5 |
If through Transact Account I have access to Sierra Charte, am I also eligible for a 30% discount?
[2019-09-03 03:02:47] |
Yes. You just run Sierra Chart independently from your Transact account using the shortcut for Sierra Chart on your desktop. It will be the one that is pointing to this program: C:\SierraChart\SierraChartTransActMA\SierraChart.exe The Account Name that receives the discount will be the one that begins with Transact_User_ And follow the instructions here: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access ---- You then will just always run Sierra Chart independent from the Transact trading software. If necessary here are the instructions to connect Sierra Chart to Transact: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-03 03:05:50
