Date/Time: Sun, 19 May 2024 18:37:09 +0000
Trying to connect Interactive brokers to sierra charts
View Count: 2259
[2019-08-30 18:08:08] |
psp777 - Posts: 2 |
Hi, I just signed up for the demo of Sierra Charts. I am trying to connect my IB account to Sierra charts, but no luck. I have attached a screen shot of the error. Thanks |
Screen Shot 2019-08-30 at 11.06.20 AM.jpg / V - Attached On 2019-08-30 18:06:43 UTC - Size: 493.65 KB - 461 views Attachment Deleted. |
[2019-08-30 18:27:49] |
Follow step number 26 here: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#IBResolvingConnectionIssue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-30 18:54:49] |
psp777 - Posts: 2 |
I am running parallel desktop on a mac. Does the open TWS need to be loaded into Parallels desktop in order for Sierra charts to work. Or can I have TWS open in my mac and Sierra open in Parallels? I have cked the settings multiple times and change the posts etc. without success. My only thought is having TWS in parallels?
[2019-08-30 22:41:24] |
Or can I have TWS open in my mac and Sierra open in Parallels? Yes you can but you need to specify the IP address in the Global Settings >> Data/Trade Service Settings >> Service Setting >>Server Address and Port setting of where TWS is running.Otherwise you do have to run TWS within Parallels. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
