Date/Time: Sun, 19 May 2024 21:02:10 +0000
running problem
View Count: 472
[2019-08-30 13:23:02] |
Laurunrun - Posts: 11 |
I have got a problem while I change to MHI -09. the program can't run and quite the problem . pls help and advise me how to settle it. |
[2019-08-30 18:12:09] |
The first thing we want you to do is to run Sierra Chart in Safe Mode . Instructions: Sierra Chart - Software Login Instructions: Using Safe Mode Tell us the exact symbol you are using. We see you are using Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
