Date/Time: Sun, 19 May 2024 20:00:15 +0000
How to permanently UNHIDE hidden window?
View Count: 1604
[2019-08-30 11:04:21] |
User462086 - Posts: 193 |
Hi, I would like to change a hidden window back to a "normal" window. To view the hidden I can use 'Window > Restore' or double click on its tab, but it becomes hidden again when I either close its chartbook or navigate to another chartbook, then back. Many thanks!! |
[2019-08-30 17:06:03] |
How was the window hidden to begin with? If you used Window >> Hide Window you then just select it from the CW menu to make it visible again. Additionally: We do not observe this happening and can not reproduce it. The closest we can come up with is if the window is detached, then when you switch to another chartbook or close and open a Chartbook, the window could will be behind the main program window, so it is not hidden, it is just lower in the view ranking. If this is the case, you can access that window through the icon for it on the Windows Task Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-30 17:07:27
