Date/Time: Sun, 19 May 2024 20:00:12 +0000
Chart DOM highlight background color
View Count: 1149
[2019-08-30 09:00:41] |
User392279 - Posts: 67 |
As attached, where these settings are?
2019-08-30_165705.png / V - Attached On 2019-08-30 08:58:29 UTC - Size: 155.39 KB - 471 views |
[2019-08-30 18:01:27] |
The following two color settings control the outline color of the chart DOM highlight box: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Buy Column Lines (also Order Entry Highlight Box) Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Sell Column Lines (also Order Entry Highlight Box) To set these, refer to the top of this page: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM Not sure why the background color looks the way it does. Did you enable the OpenGL option in the Global Settings >> Graphics Settings? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-30 18:03:35
[2019-08-30 18:28:38] |
These 2 Options grayed out on global graphics setting. But Chart DOM Ask/Bid Column Background can be enabled. |
[2019-08-30 18:30:11] |
Yes, OpenGL enabled. Does OpenGL get better perfermance? or should I turn it off?
