Date/Time: Sun, 24 Nov 2024 21:57:19 +0000
Brent Crude Pivots
View Count: 1240
[2013-12-10 09:46:51] |
User54027 - Posts: 128 |
Hi, When loading brent crude pivots onto my 5 min chart it will not display any levels. I am manually inputting OHLC but no results on screen. I do not have this problem with my Dow, Dax or Italian 40 charts. Thanks, Justin |
[2013-12-11 03:08:46] |
Refer to this section: http://www.sierrachart.com/index.php?l=doc/doc_PivotPoints.html#PivotPointsNotVisible (Pivot Points Not Visible) If you still need help, we will need to get a Chartbook containing a single chart with Pivot Points showing the problem. Here are the instructions to attach it: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
