Date/Time: Wed, 16 Sep 2026 00:31:23 +0000
[User Discussion] - QQE indicator?
View Count: 7968
[2019-08-30 03:26:19]
Freshie - Posts: 5
Hi, I read in this thread Candle Study and QQE Histogram there is an existing QQE indicator for SC? However it does not appear in my study and custom study list.
Is there something I need to download to enable it? Thanks
[2019-08-30 15:08:56]
John - SC Support - Posts: 47903
QQE is a User Contributed Study, not a built-in study from Sierra Chart. To use this study select Analysis >> Studies then on the Chart Studies window select Add Custom Study, then select the + sign next to the section for User Contributed Studies, then scroll down to the QQE study.
You will find the information for how to open other studies in step #3 of the documentation here:
Chart Studies: Adding/Modifying Chart Studies
Date Time Of Last Edit: 2019-08-30 15:13:31
[2019-08-31 02:22:00]
Freshie - Posts: 5
Thanks! I did try to add custom studies before posting, but did not notice the "User Contributed Studies" all the way bottom. Added it and am comparing it now with my other platform version.
[2019-08-31 15:20:20]
User90125 - Posts: 715
Another version of QQE (Quantative Qualitative Estimation) can be found in user Kiwi's custom code, found here:
https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/Kiwi.cpp
Compile it yourself and see if it fits what you may be looking for.
attachmentKiwi.cpp - Attached On 2019-08-31 15:19:30 UTC - Size: 211.29 KB - 461 views
[2019-09-01 09:19:13]
Ackin - Posts: 1865
"Another version of QQE (Quantitative Qualitative Estimation) can be found in user's Kiwi code"
Only note: It's not different but the same version .... (according to the parameters in the settings is identical with QQE in the Contributed Studies)
