Date/Time: Sun, 02 Feb 2025 06:44:06 +0000
Mixing CQG data feed with Denali data feed supported?
View Count: 1302
[2019-08-29 17:16:56]
User266069 - Posts: 30
im with AMP, and my plan is to use
1) CQG data feed for HKEX market
2) Denali data feed for CME market with CQG routing
is using two different data feed supported?
one more thing, if i were to use SC data feed for HKEX market as well, for HKEX alone ill have to pay $25 + $16 right?
thank you
Date Time Of Last Edit: 2019-08-29 17:30:21
[2019-08-29 18:35:28]
Yes this is fully supported. There is nothing special you need to do. Other than following the instructions here to use the Denali Exchange Data Feed:
Yes this is correct and this is the data feed you will need to use:
Sierra Chart Exchange Data Feed
