Date/Time: Sun, 02 Feb 2025 07:01:07 +0000
Reversal bars and DOM
View Count: 705
[2019-08-29 16:31:46]
User166512 - Posts: 5
I can’t display ask and bid pull as well as CT bid and CT ask on the DOM. How can I do so? See attachment 1
Also when i want the chart to show 10 ticks reversal bars I see only a black screen. Am I missing something? How can I display the chart as shown in attachment 2?
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=31076
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=31077
[2019-08-29 18:47:23]
1. Refer to the instructions here to add/change columns in the Trading DOM:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
2. The chart in your second image uses the Numbers Bars study. Refer to the following for the Numbers Bars study:
Numbers Bars
If you are having a problem displaying the basic Reversal bars, then we need to help with that first. Set up your chart with the reversal bars:
Changing Chart Bars Period
And then reset your right-side scale to ensure that you are in the correct location to display the bars. Refer to the following to reset the scales:
Chart Scale and Scale Adjusting: Resetting the Scale
If you still are not seeing anything, then post an image of your chart using these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage
Date Time Of Last Edit: 2019-08-29 18:49:37
