Date/Time: Sun, 24 Nov 2024 21:18:24 +0000
Do I need the DTN IQFeed?
View Count: 1866
[2013-12-10 09:27:42] |
User34597 - Posts: 11 |
Hey guys, I wish to trade Eurex futures and have been told I need the DTN IQFeed to get historical intraday data. If I DO NOT get this plug in will I still be able to get current intraday data for Eurex or none at all? I don't need historical data going back years I only need the current active front month daily and hourly candles. I'm a little confused re above but thank you. (I have package 5 with a TT feed) Alternatively if I wait till year end will SC be able to provide historical intraday data and market depth for Eurex as per previous discussion threads or will I still need DTN?. Thks Date Time Of Last Edit: 2013-12-10 11:26:08
[2013-12-10 18:03:03] |
To our knowledge Velocity does not support EUREX trading on the FIX Adapter which Sierra Chart connects to when using Velocity. So you cannot trade the EUREX or get market data through Velocity when using Sierra Chart. At least that is our understanding. If you want EUREX market data, then you can obtain that from us in a couple of weeks with our new data feed: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php You definitely will not be needing DTN. Our recommendation is to wait. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-10 18:26:21] |
My new broker is Deep Discount Trading and I want to trade Eurex via them
Date Time Of Last Edit: 2013-12-10 18:29:08
[2013-12-10 18:54:52] |
You can trade EUREX through Deep Discount Trading using TT FIX. For the historical EUREX data, you will need to wait until that becomes available in about two weeks. This is one of our priorities. Keep in mind there will be an exchange fee. It currently is $30 and that includes market depth. Later on if you just need top of book data, there will be the ability to get that separately for 15 a month. And then you have to pay $35 for the EUREX data feed. This is both a real-time and historical data feed so all EUREX data will come from our own data feed. It is not possible to only get the historical Intraday data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
