Date/Time: Sun, 02 Feb 2025 06:46:04 +0000
unable to connect
View Count: 681
[2019-08-29 13:43:51]
User372626 - Posts: 59
Reading Internal Order ID file. | 2019-08-29 07:53:04.051
Reading Trade Orders file. | 2019-08-29 07:53:04.131
Reading Trade Positions file. | 2019-08-29 07:53:04.133
Reading Account Balance file. | 2019-08-29 07:53:04.134
UDPListener (1340). Port 22904 | Listening on UDP port 22904. | 2019-08-29 07:53:04.153
Software version: 1962 64-bit | 2019-08-29 07:53:04.153
Usage end date: 2020-07-07 | 2019-08-29 07:53:04.153
Enabled for: Advanced Features 2. | 2019-08-29 07:53:04.153
Enabled for: Sierra Chart Historical Data Service. | 2019-08-29 07:53:04.153
Enabled for: Sierra Chart Bundled Real-Time Exchange Data Feed. | 2019-08-29 07:53:04.153
Enabled for exchange2: CME | 2019-08-29 07:53:04.153
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-08-29 07:53:04.153
Current selected Data/Trading service: SC Futures Order Routing/Data | 2019-08-29 07:53:04.153
Custom symbol settings values: disabled | 2019-08-29 07:53:04.153
Chart Update Interval: 500 | 2019-08-29 07:53:04.153
Intraday Data Storage Time Unit: 0 | 2019-08-29 07:53:04.153
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-08-29 07:53:04.153
2019-08-29 20:53:04 Local computer time | 2019-08-29 07:53:04.153
2019-08-29 12:53:04 Local computer time in UTC | 2019-08-29 07:53:04.153
2019-08-29 07:53:04 Local computer time in SC Time Zone | 2019-08-29 07:53:04.153
2019-08-29 12:53:06 Server time in UTC | 2019-08-29 07:53:04.153
Local computer UTC time and Server UTC time difference: 3 seconds. | 2019-08-29 07:53:04.153
Program path: C:\SierraChart\ | 2019-08-29 07:53:04.153
Data Files path: C:\SierraChart\Data\ | 2019-08-29 07:53:04.153
OS Version Number: 10.0 | 2019-08-29 07:53:04.154
Locale Setting: C | 2019-08-29 07:53:04.154
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-08-29 07:53:04.155
Created the DTC Protocol server. | 2019-08-29 07:53:04.169
DTC Protocol Server listening on port 11099. | 2019-08-29 07:53:04.170
Created the DTC Protocol historical data server. | 2019-08-29 07:53:04.170
HD Server Manager | Listening on port 11098 | 2019-08-29 07:53:04.172
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures.dtc.trading. Request ID: 1. | 2019-08-29 07:53:04.172
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:53:04.728
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-08-29 07:53:04.936
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-08-29 07:53:04.936
Received 5 login tokens. | 2019-08-29 07:53:04.969
Symbol settings MD5 received. Request ID: 1. | 2019-08-29 07:53:05.093
Symbol settings are up-to-date for sc_futures.dtc.trading. | 2019-08-29 07:53:05.093
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:53:05.214
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-08-29 07:53:05.448
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-08-29 07:53:05.448
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-08-29 07:53:06.169
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-08-29 07:53:06.169
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:53:07.340
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-08-29 07:53:07.552
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-08-29 07:53:07.552
SC Futures Order Routing/Data | Connecting to the server futurestrading5.sierracharts.com. Port 443 | 2019-08-29 07:53:10.095
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2019-08-29 07:53:10.423
DTC Client socket (1) | Connecting to IP: 209.58.163.194. | 2019-08-29 07:53:10.423
SC Futures Order Routing/Data | Connected to server. | 2019-08-29 07:53:11.751
SC Futures Order Routing/Data | Starting socket receive thread. | 2019-08-29 07:53:11.751
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-08-29 07:53:11.751
Service connection timed out. Will disconnect and retry. | 2019-08-29 07:54:10.095 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-29 07:54:10.095
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-29 07:54:10.095
DTC Client socket (1) | Write in progress. Shutdown being delayed. | 2019-08-29 07:54:10.124
SC Futures Order Routing/Data | Disconnected. | 2019-08-29 07:54:10.124
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-29 07:54:10.124
SC Futures Order Routing/Data | Connecting to the server futurestrading5.sierracharts.com. Port 443 | 2019-08-29 07:54:11.120
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2019-08-29 07:54:12.266
DTC Client socket (2) | Connecting to IP: 209.58.163.194. | 2019-08-29 07:54:12.267
SC Futures Order Routing/Data | Connected to server. | 2019-08-29 07:54:12.592
SC Futures Order Routing/Data | Starting socket receive thread. | 2019-08-29 07:54:12.592
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-08-29 07:54:12.592
Service connection timed out. Will disconnect and retry. | 2019-08-29 07:55:11.121 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-29 07:55:11.121
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-29 07:55:11.121
DTC Client socket (2) | Write in progress. Shutdown being delayed. | 2019-08-29 07:55:11.249
SC Futures Order Routing/Data | Disconnected. | 2019-08-29 07:55:11.249
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-29 07:55:11.249
SC Futures Order Routing/Data | Connecting to the server futurestrading5.sierracharts.com. Port 443 | 2019-08-29 07:55:12.256
DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2019-08-29 07:55:12.259
DTC Client socket (3) | Connecting to IP: 209.58.163.194. | 2019-08-29 07:55:12.259
SC Futures Order Routing/Data | Connected to server. | 2019-08-29 07:55:12.593
SC Futures Order Routing/Data | Starting socket receive thread. | 2019-08-29 07:55:12.593
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-08-29 07:55:12.593
SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2019-08-29 07:55:14.283
SC Futures Order Routing/Data | Sending logon request message. | 2019-08-29 07:55:14.283
SC Futures Order Routing/Data | Received logon response. | 2019-08-29 07:55:20.189
SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2019-08-29 07:55:20.189
SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2019-08-29 07:55:20.189
SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2019-08-29 07:55:20.189
SC Futures Order Routing/Data | Trading is supported. | 2019-08-29 07:55:20.189
SC Futures Order Routing/Data | Order cancel and replace is supported. | 2019-08-29 07:55:20.189
SC Futures Order Routing/Data | OCO Orders supported. | 2019-08-29 07:55:20.189
SC Futures Order Routing/Data | Bracket Orders supported. | 2019-08-29 07:55:20.189
SC Futures Order Routing/Data | Connected to data and trading server. | 2019-08-29 07:55:20.189
DTC Client socket (1) | Timed out waiting for final send. Canceling I/O. | 2019-08-29 07:55:29.506
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-08-29 07:55:29.506
DTC Client socket (1) | Write has completed. Shutdown being performed. | 2019-08-29 07:55:29.506
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-08-29 07:55:29.506
DTC Client socket (1) | Closed. | 2019-08-29 07:55:29.506
MESU19_FUT_CME 2.00 Range #1 | Reloading chart. | 2019-08-29 07:55:41.013
MESU19_FUT_CME 60 Min #2 | Reloading chart. | 2019-08-29 07:55:41.139
MESU19_FUT_CME #3 | Reloading chart. | 2019-08-29 07:55:41.233
MESU19_FUT_CME [C] Weekly #4 | Reloading chart. | 2019-08-29 07:55:41.357
MESU19_FUT_CME [C] Weekly #4 | Performing historical Daily data download for symbol MESM19_FUT_CME starting at 2019-03-07. | 2019-08-29 07:55:41.381
MESU19_FUT_CME [C] Weekly #4 | Performing historical Daily data download for symbol MESU19_FUT_CME starting at last date in file. | 2019-08-29 07:55:41.383
MESU19_FUT_CME [C] Weekly #4 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2019-08-29 07:55:41.405 *
MESU19_FUT_CME [C] Weekly #4 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2019-08-29 07:55:41.405
MESU19_FUT_CME 240 Min #5 | Reloading chart. | 2019-08-29 07:55:41.519
MESU19_FUT_CME #6 | Reloading chart. | 2019-08-29 07:55:41.531
MESU19_FUT_CME 5 Min #7 | Reloading chart. | 2019-08-29 07:55:41.654
MESU19_FUT_CME 60 Min #8 | Reloading chart. | 2019-08-29 07:55:41.774
ESU19_FUT_CME [C] 1 Day #2 | Reloading chart. | 2019-08-29 07:55:41.957
ESU19_FUT_CME 5 Min #3 | Reloading chart. | 2019-08-29 07:55:42.085
ESU19_FUT_CME #5 | Reloading chart. | 2019-08-29 07:55:42.448
ESU19_FUT_CME [C] 2.50 Range #7 | Reloading chart. | 2019-08-29 07:55:42.607
ESU19_FUT_CME [C] 15 Min #1 | Reloading chart. | 2019-08-29 07:55:42.765
ESU19_FUT_CME Delta 200v #4 | Reloading chart. | 2019-08-29 07:55:43.006
ESU19_FUT_CME 5 Min #1 | Reloading chart. | 2019-08-29 07:55:43.312
ESU19_FUT_CME 60 Min #3 | Reloading chart. | 2019-08-29 07:55:43.539
ESU19_FUT_CME #5 | Reloading chart. | 2019-08-29 07:55:43.881
ESU19_FUT_CME [C] Daily #6 | Reloading chart. | 2019-08-29 07:55:44.270
ESU19_FUT_CME [C] Daily #6 | Performing historical Daily data download for symbol ESU19_FUT_CME starting at last date in file. | 2019-08-29 07:55:46.904
ESU19_FUT_CME [C] Daily #6 | Waiting for historical downloads to complete with the IDs: 3, | 2019-08-29 07:55:47.373
ESU19_FUT_CME 240 Min #4 | Reloading chart. | 2019-08-29 07:55:47.604
ESU19_FUT_CME #7 | Reloading chart. | 2019-08-29 07:55:47.652
ESU19_FUT_CME 5 Min #8 | Reloading chart. | 2019-08-29 07:55:47.918
ESU19_FUT_CME 30 Min #2 | Reloading chart. | 2019-08-29 07:55:48.227
ESU19_FUT_CME Delta 200v #9 | Reloading chart. | 2019-08-29 07:55:48.502
Mapping MESM19_FUT_CME to MESM19. Service code: cme | 2019-08-29 07:55:49.472
HD Request # 2 | Downloading Historical Daily chart data for MESM19_FUT_CME. Starting date: 2019-03-07. Service: sc_futures.dtc.trading | 2019-08-29 07:55:49.472
Historical data download counter reset. | 2019-08-29 07:55:49.472
HD Request # 2 | Requesting historical Daily data for ETM19 starting at 2019-03-06 | 2019-08-29 07:55:49.473
Mapping MESU19_FUT_CME to MESU19. Service code: cme | 2019-08-29 07:55:49.474
SC Data - All Services | Starting real-time market data updates for: MESU19_FUT_CME (MESU19). ID: 2 Service code: cme | 2019-08-29 07:55:49.474
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2019-08-29 07:55:49.474
SC Data - All Services | Requesting security definition data for: MESU19_FUT_CME (MESU19). ID: 2 | 2019-08-29 07:55:49.474
Intraday data recording state for symbol MESU19_FUT_CME is set to download 'Pending'. | 2019-08-29 07:55:49.474
MESU19_FUT_CME #6 | StartDateTimeForLoadingOrderFills: 2019-08-26 10:12:21 | 2019-08-29 07:55:49.475
MESU19_FUT_CME 60 Min #2 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:00:00 | 2019-08-29 07:55:49.476
MESU19_FUT_CME #3 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:24:00 | 2019-08-29 07:55:49.479
MESU19_FUT_CME 5 Min #7 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:20:00 | 2019-08-29 07:55:49.731
ESU19_FUT_CME #5 | StartDateTimeForLoadingOrderFills: 2019-08-26 10:12:22 | 2019-08-29 07:55:49.741
Mapping ESU19_FUT_CME to ESU19. Service code: cme | 2019-08-29 07:55:49.747
SC Data - All Services | Starting real-time market data updates for: ESU19_FUT_CME (ESU19). ID: 3 Service code: cme | 2019-08-29 07:55:49.747
SC Data - All Services | Requesting security definition data for: ESU19_FUT_CME (ESU19). ID: 3 | 2019-08-29 07:55:49.747
Intraday data recording state for symbol ESU19_FUT_CME is set to download 'Pending'. | 2019-08-29 07:55:49.747
Requesting market depth updates for: ESU19_FUT_CME if supported. | 2019-08-29 07:55:49.795
Separate subscription for market depth updates not supported. ESU19_FUT_CME | 2019-08-29 07:55:49.795
Requesting market depth updates for: MESU19_FUT_CME if supported. | 2019-08-29 07:55:49.795
Separate subscription for market depth updates not supported. MESU19_FUT_CME | 2019-08-29 07:55:49.795
ESU19_FUT_CME #7 | StartDateTimeForLoadingOrderFills: 2019-08-26 10:12:22 | 2019-08-29 07:55:49.798
HTTPS connection ID:1 to historicaldata.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-08-29 07:55:49.996
HTTPS connection ID:1 to historicaldata.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 88.99.0.216. | 2019-08-29 07:55:49.997
DTC Client socket (4) | Creating socket. | 2019-08-29 07:55:50.281
DTC Client socket (4) | Connecting to IP: 216.1.90.129. | 2019-08-29 07:55:50.281
Delaying start of download for MESU19_FUT_CME | 2019-08-29 07:55:50.747
MESU19_FUT_CME[M] 240 Min #5 | StartDateTimeForLoadingOrderFills: 2019-05-06 09:00:00 | 2019-08-29 07:55:50.758
SC Data - All Services | Connected to server. | 2019-08-29 07:55:50.911
SC Data - All Services | Starting socket receive thread. | 2019-08-29 07:55:50.911
SC Data - All Services | Sending encoding request to server: Binary VLS | 2019-08-29 07:55:50.911
SC Futures Order Routing/Data | Received security definition for symbol MESU19_FUT_CME | 2019-08-29 07:55:50.912
SC Futures Order Routing/Data | Received security definition for symbol ESU19_FUT_CME | 2019-08-29 07:55:50.912
SC Data - All Services | Setting DTC encoding to Binary VLS | 2019-08-29 07:55:51.178
SC Data - All Services | Sending logon request message. | 2019-08-29 07:55:51.178
MESU19_FUT_CME[M] 2.00 Range #1 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:24:36 | 2019-08-29 07:55:51.685
SC Data - All Services | Received logon response. | 2019-08-29 07:55:52.090
SC Data - All Services | Server Name: SC Realtime Server. | 2019-08-29 07:55:52.090
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2019-08-29 07:55:52.090
SC Data - All Services | Successfully connected. | 2019-08-29 07:55:52.090
SC Data - All Services | Trading is not supported. | 2019-08-29 07:55:52.090
SC Data - All Services | Restarting real-time data updates for symbol: ESU19_FUT_CME -> ESU19 | 2019-08-29 07:55:52.090
SC Data - All Services | Restarting real-time data updates for symbol: MESU19_FUT_CME -> MESU19 | 2019-08-29 07:55:52.090
HD Request # 2 | Receiving historical Daily data for MESM19_FUT_CME starting at 2019-05-01 | 2019-08-29 07:55:52.268
HD Request # 2 | Writing historical Daily data to the file MESM19_FUT_CME.dly | 2019-08-29 07:55:52.269
HD Request # 2 | Received 37 records from 2019-05-01 00:00:00 to 2019-06-21 00:00:00 (52.0 days) and wrote 37 records for MESM19_FUT_CME | 2019-08-29 07:55:52.269
HD Request # 2 | Completion time: 3s | 2019-08-29 07:55:52.336
HD Request # 2 | Daily data download complete for MESM19_FUT_CME. Unique request ID: 1 | 2019-08-29 07:55:52.336
Removed historical data download ID 1 | 2019-08-29 07:55:52.336
HD Request # 3 | Downloading Historical Daily chart data for MESU19_FUT_CME. Starting date: 2019-08-27. Service: sc_futures.dtc.trading | 2019-08-29 07:55:52.346
HD Request # 3 | Requesting historical Daily data for ETU19 starting at 2019-08-26 | 2019-08-29 07:55:52.346
HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (5) | Creating socket. Using TLS 1.2. | 2019-08-29 07:55:52.346
HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (5) | Connecting to IP: 88.99.0.216. | 2019-08-29 07:55:52.347
HTTPS connection ID:1 to historicaldata.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:55:52.585
MESU19_FUT_CME[M] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:00:00 | 2019-08-29 07:55:53.285
SC Data - All Services | Clearing market depth for ESU19_FUT_CME. | 2019-08-29 07:55:53.538
SC Data - All Services | Received security definition for symbol ESU19_FUT_CME | 2019-08-29 07:55:53.538
SC Data - All Services | Clearing market depth for MESU19_FUT_CME. | 2019-08-29 07:55:53.986
SC Data - All Services | Received security definition for symbol MESU19_FUT_CME | 2019-08-29 07:55:53.986
HTTPS connection ID:1 to historicaldata.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-08-29 07:55:54.084
HTTPS connection ID:1 to historicaldata.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-08-29 07:55:54.084
HD Request # 3 | Receiving historical Daily data for MESU19_FUT_CME starting at 2019-08-27 | 2019-08-29 07:55:54.191
HD Request # 3 | Writing historical Daily data to the file MESU19_FUT_CME.dly | 2019-08-29 07:55:54.191
HD Request # 3 | Received 4 records from 2019-08-27 00:00:00 to 2019-08-29 00:00:00 (3.0 days) and wrote 3 records for MESU19_FUT_CME | 2019-08-29 07:55:54.193
HD Request # 3 | Completion time: 2s | 2019-08-29 07:55:54.589
HD Request # 3 | Daily data download complete for MESU19_FUT_CME. Unique request ID: 2 | 2019-08-29 07:55:54.589
Removed historical data download ID 2 | 2019-08-29 07:55:54.589
MESU19_FUT_CME [C] Weekly #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-08-29 07:55:54.631
MESU19_FUT_CME [C] Weekly #4 | Reloading chart. | 2019-08-29 07:55:54.633
HD Request # 4 | Downloading Historical Daily chart data for ESU19_FUT_CME. Starting date: 2019-08-27. Service: sc_futures.dtc.trading | 2019-08-29 07:55:54.735
HD Request # 4 | Requesting historical Daily data for ESU19 starting at 2019-08-26 | 2019-08-29 07:55:54.735
HTTPS connection ID:3 to historicaldata.sierrachart.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2019-08-29 07:55:54.735
HTTPS connection ID:3 to historicaldata.sierrachart.com:443 for request ID:3 (1) | Connecting to IP: 88.99.0.216. | 2019-08-29 07:55:54.735
HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (5) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:55:54.828
MESU19_FUT_CME [C] Weekly #4 | Reloading chart. | 2019-08-29 07:55:55.239
MESU19_FUT_CME [C] Weekly #4 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2019-08-29 07:55:55.276 *
MESU19_FUT_CME [C][M] Weekly #4 | StartDateTimeForLoadingOrderFills: 2019-08-27 07:55:55 | 2019-08-29 07:55:55.781
HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (5) | Socket gracefully closed by remote side. | 2019-08-29 07:55:56.336
HTTPS connection ID:2 to historicaldata.sierrachart.com:443 for request ID:2 (5) | Closed. | 2019-08-29 07:55:56.336
HD Request # 4 | Receiving historical Daily data for ESU19_FUT_CME starting at 2019-08-27 | 2019-08-29 07:55:57.771
HD Request # 4 | Writing historical Daily data to the file ESU19_FUT_CME.dly | 2019-08-29 07:55:57.771
HD Request # 4 | Received 4 records from 2019-08-27 00:00:00 to 2019-08-29 00:00:00 (3.0 days) and wrote 3 records for ESU19_FUT_CME | 2019-08-29 07:55:57.775
HD Request # 4 | Completion time: 4s | 2019-08-29 07:55:58.446
HD Request # 4 | Daily data download complete for ESU19_FUT_CME. Unique request ID: 3 | 2019-08-29 07:55:58.446
Removed historical data download ID 3 | 2019-08-29 07:55:58.446
HD Request # 5 | Downloading Intraday chart data for MESU19_FUT_CME to the file MESU19_FUT_CME.scid. Service: cme | 2019-08-29 07:55:58.460
HD Request # 5 | Download start date-time: 2019-08-28 10:12:21.000 | 2019-08-29 07:55:58.460
HD Request # 5 | Using server: ds21.sierracharts.com port 10150 | 2019-08-29 07:55:58.460
Socket (5) | Creating socket. | 2019-08-29 07:55:58.460
Socket (5) | Connecting to IP: 216.1.90.129. | 2019-08-29 07:55:58.460
ESU19_FUT_CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2019-07-29 06:00:00 | 2019-08-29 07:55:58.466
ESU19_FUT_CME [C] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2019-08-29 07:55:58.476
ESU19_FUT_CME [C] Daily #6 | Reloading chart. | 2019-08-29 07:55:58.477
HD Request # 6 | Downloading Historical Daily chart data for MESU19_FUT_CME. Starting date: 2019-08-28. Service: sc_futures.dtc.trading | 2019-08-29 07:55:58.566
HD Request # 6 | Requesting historical Daily data for ETU19 starting at 2019-08-27 | 2019-08-29 07:55:58.566
HTTPS connection ID:4 to historicaldata.sierrachart.com:443 for request ID:4 (6) | Creating socket. Using TLS 1.2. | 2019-08-29 07:55:58.566
HTTPS connection ID:4 to historicaldata.sierrachart.com:443 for request ID:4 (6) | Connecting to IP: 88.99.0.216. | 2019-08-29 07:55:58.566
ESU19_FUT_CME [C] Daily #6 | StartDateTimeForLoadingOrderFills: 2016-08-30 00:00:00 | 2019-08-29 07:55:58.647
HD Request # 5 | Setting DTC encoding to Binary VLS | 2019-08-29 07:55:58.868
HD Request # 5 | Sending historical data logon request message. | 2019-08-29 07:55:58.868
HTTPS connection ID:3 to historicaldata.sierrachart.com:443 for request ID:3 (1) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:55:58.871
ESU19_FUT_CME[M] 5 Min #3 | Reloading chart. | 2019-08-29 07:55:58.985
ESU19_FUT_CME [C] Daily #6 | Reloading chart. | 2019-08-29 07:55:59.081
HTTPS connection ID:3 to historicaldata.sierrachart.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2019-08-29 07:55:59.106
HTTPS connection ID:3 to historicaldata.sierrachart.com:443 for request ID:3 (1) | Closed. | 2019-08-29 07:55:59.106
ESU19_FUT_CME [C][M] Daily #6 | StartDateTimeForLoadingOrderFills: 2019-08-27 07:56:01 | 2019-08-29 07:55:59.599
HD Request # 5 | Requesting Intraday data. Start date-time: 2019-08-28 10:12:21. Record interval: 0. Symbol: MESU19 | 2019-08-29 07:56:00.084
HD Request # 5 | Decompressing data. | 2019-08-29 07:56:00.287
ESU19_FUT_CME[M] Delta 200v #4 | StartDateTimeForLoadingOrderFills: 2019-07-29 06:00:00 | 2019-08-29 07:56:00.559
HD Request # 6 | Receiving historical Daily data for MESU19_FUT_CME starting at 2019-08-28 | 2019-08-29 07:56:00.628
HD Request # 6 | Writing historical Daily data to the file MESU19_FUT_CME.dly | 2019-08-29 07:56:00.628
HD Request # 6 | Received 3 records from 2019-08-28 00:00:00 to 2019-08-29 00:00:00 (2.0 days) and wrote 2 records for MESU19_FUT_CME | 2019-08-29 07:56:00.629
HD Request # 6 | Completion time: 2s | 2019-08-29 07:56:00.664
HD Request # 6 | Daily data download complete for MESU19_FUT_CME. Unique request ID: 6 | 2019-08-29 07:56:00.664
Removed historical data download ID 6 | 2019-08-29 07:56:00.664
HD Request # 7 | Downloading Historical Daily chart data for ESU19_FUT_CME. Starting date: 2019-08-28. Service: sc_futures.dtc.trading | 2019-08-29 07:56:00.714
HD Request # 7 | Requesting historical Daily data for ESU19 starting at 2019-08-27 | 2019-08-29 07:56:00.714
HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (1) | Creating socket. Using TLS 1.2. | 2019-08-29 07:56:00.714
HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (1) | Connecting to IP: 88.99.0.216. | 2019-08-29 07:56:00.715
HTTPS connection ID:4 to historicaldata.sierrachart.com:443 for request ID:4 (6) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:56:00.921
MESU19_FUT_CME [C][M] Weekly #4 | Reloading chart. | 2019-08-29 07:56:01.020
MESU19_FUT_CME [C][M] Weekly #4 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME | 2019-08-29 07:56:01.056 *
HTTPS connection ID:4 to historicaldata.sierrachart.com:443 for request ID:4 (6) | Socket gracefully closed by remote side. | 2019-08-29 07:56:01.151
HTTPS connection ID:4 to historicaldata.sierrachart.com:443 for request ID:4 (6) | Closed. | 2019-08-29 07:56:01.151
ESU19_FUT_CME[M] Delta 200v #4 | Reloading chart. | 2019-08-29 07:56:01.159
MESU19_FUT_CME [C][M] Weekly #4 | StartDateTimeForLoadingOrderFills: 2019-08-27 07:56:02 | 2019-08-29 07:56:01.550
HD Request # 5 | Receiving Intraday data for MESU19_FUT_CME starting at 2019-08-28 10:12:21 | 2019-08-29 07:56:02.022
HD Request # 5 | Timestamp of first Intraday data file record written: 2019-08-28 10:12:25 | 2019-08-29 07:56:02.023
HD Request # 7 | Receiving historical Daily data for ESU19_FUT_CME starting at 2019-08-28 | 2019-08-29 07:56:03.155
HD Request # 7 | Writing historical Daily data to the file ESU19_FUT_CME.dly | 2019-08-29 07:56:03.155
HD Request # 7 | Received 3 records from 2019-08-28 00:00:00 to 2019-08-29 00:00:00 (2.0 days) and wrote 2 records for ESU19_FUT_CME | 2019-08-29 07:56:03.158
HD Request # 7 | Completion time: 3s | 2019-08-29 07:56:03.237
HD Request # 7 | Daily data download complete for ESU19_FUT_CME. Unique request ID: 7 | 2019-08-29 07:56:03.237
Removed historical data download ID 7 | 2019-08-29 07:56:03.237
ESU19_FUT_CME [C][M] Daily #6 | Reloading chart. | 2019-08-29 07:56:03.332
HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (1) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:56:03.830
ESU19_FUT_CME [C][M] Daily #6 | StartDateTimeForLoadingOrderFills: 2016-08-30 00:00:00 | 2019-08-29 07:56:03.963
HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (1) | Socket gracefully closed by remote side. | 2019-08-29 07:56:04.095
HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (1) | Closed. | 2019-08-29 07:56:04.095
ESU19_FUT_CME [C][M] 1 Day #2 | StartDateTimeForLoadingOrderFills: 2019-07-29 21:30:00 | 2019-08-29 07:56:08.354
DTC Client socket (2) | Write has completed. Shutdown being performed. | 2019-08-29 07:56:09.143
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:56:09.143
ESU19_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2019-07-29 21:30:00 | 2019-08-29 07:56:09.182
DTC Client socket (2) | Socket gracefully closed by remote side. | 2019-08-29 07:56:09.468
DTC Client socket (2) | Closed. | 2019-08-29 07:56:09.468
ESU19_FUT_CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2019-07-29 06:00:00 | 2019-08-29 07:56:11.802
ESU19_FUT_CME[M] 240 Min #4 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 07:56:12.100
ESU19_FUT_CME[M] Delta 200v #9 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:55 | 2019-08-29 07:56:12.785
ESU19_FUT_CME [C][M] 2.50 Range #7 | StartDateTimeForLoadingOrderFills: 2019-07-29 21:30:00 | 2019-08-29 07:56:13.677
ESU19_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 07:56:13.952
ESU19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 07:56:15.411
ESU19_FUT_CME[M] 60 Min #3 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 07:56:15.685
ESU19_FUT_CME[M] Delta 200v #4 | StartDateTimeForLoadingOrderFills: 2019-07-29 06:00:00 | 2019-08-29 07:56:16.158
ESU19_FUT_CME[M] 5 Min #8 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 07:56:16.577
Socket (5) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:56:17.026
Historical data download thread signaled to stop. | 2019-08-29 07:56:17.027
HD Request # 5 | Received 107808 records from 2019-08-28 10:12:21.000 to 2019-08-29 07:56:08.002 (21.7 hours) and wrote 107805 records for MESU19_FUT_CME | 2019-08-29 07:56:17.028
Added 8 Time and Sales records to Intraday data file for MESU19_FUT_CME after download. | 2019-08-29 07:56:17.030
HD Request # 5 | Completion time: 19s | 2019-08-29 07:56:17.033
HD Request # 5 | Intraday data download complete for MESU19_FUT_CME. Unique request ID: 4 | 2019-08-29 07:56:17.033
Removed historical data download ID 4 | 2019-08-29 07:56:17.033
Real-time Intraday chart data file updates started for MESU19_FUT_CME | 2019-08-29 07:56:17.033
Intraday chart data file opened for MESU19_FUT_CME | 2019-08-29 07:56:17.033
HD Request # 8 | Downloading Intraday chart data for ESU19_FUT_CME to the file ESU19_FUT_CME.scid. Service: cme | 2019-08-29 07:56:17.033
HD Request # 8 | Download start date-time: 2019-08-28 10:12:22.000 | 2019-08-29 07:56:17.034
HD Request # 8 | Using server: ds22.sierracharts.com port 10149 | 2019-08-29 07:56:17.034
Socket (5) | Socket gracefully closed by remote side. | 2019-08-29 07:56:17.229
Socket (5) | Closed. | 2019-08-29 07:56:17.229
Socket (1) | Creating socket. | 2019-08-29 07:56:17.445
Socket (1) | Connecting to IP: 208.185.224.129. | 2019-08-29 07:56:17.445
HD Request # 8 | Setting DTC encoding to Binary VLS | 2019-08-29 07:56:17.838
HD Request # 8 | Sending historical data logon request message. | 2019-08-29 07:56:17.838
HD Request # 8 | Requesting Intraday data. Start date-time: 2019-08-28 10:12:22. Record interval: 0. Symbol: ESU19 | 2019-08-29 07:56:18.444
HD Request # 8 | Decompressing data. | 2019-08-29 07:56:18.640
ESU19_FUT_CME[M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 07:56:19.118
HD Request # 8 | Receiving Intraday data for ESU19_FUT_CME starting at 2019-08-28 10:12:22 | 2019-08-29 07:56:19.440
HD Request # 8 | Timestamp of first Intraday data file record written: 2019-08-28 10:12:24 | 2019-08-29 07:56:19.441
Opened cached Intraday file: C:\SierraChart\Data\MESU19_FUT_CME.scid | 2019-08-29 07:56:22.239
Historical data download thread signaled to stop. | 2019-08-29 07:57:09.138
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-29 07:57:09.138
HD Request # 8 | Received 472370 records from 2019-08-28 10:12:22.000 to 2019-08-29 07:57:03.000 (21.7 hours) and wrote 472352 records for ESU19_FUT_CME | 2019-08-29 07:57:09.139
HD Request # 8 | Completion time: 52s | 2019-08-29 07:57:09.148
HD Request # 8 | Intraday data download complete for ESU19_FUT_CME. Unique request ID: 5 | 2019-08-29 07:57:09.148
Removed historical data download ID 5 | 2019-08-29 07:57:09.148
Real-time Intraday chart data file updates started for ESU19_FUT_CME | 2019-08-29 07:57:09.148
Intraday chart data file opened for ESU19_FUT_CME | 2019-08-29 07:57:09.148
Socket (1) | Socket gracefully closed by remote side. | 2019-08-29 07:57:09.331
Socket (1) | Closed. | 2019-08-29 07:57:09.331
Opened cached Intraday file: C:\SierraChart\Data\ESU19_FUT_CME.scid | 2019-08-29 07:57:16.278
ESU19_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.786
ESU19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.802
MESU19_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.819
MESU19_FUT_CME[M] 2.00 Range #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.867
MESU19_FUT_CME[M] 60 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.942
MESU19_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.943
MESU19_FUT_CME[M] 240 Min #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.943
MESU19_FUT_CME[M] 5 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.979
MESU19_FUT_CME[M] 60 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.979
ESU19_FUT_CME [C][M] 1 Day #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.980
ESU19_FUT_CME [C][M] 2.50 Range #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.980
ESU19_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:00.980
ESU19_FUT_CME[M] 60 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.088
ESU19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.143
ESU19_FUT_CME[M] 240 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.256
ESU19_FUT_CME[M] 5 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.295
ESU19_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.314
ESU19_FUT_CME[M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.328
ESU19_FUT_CME[M] Delta 200v #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.347
ESU19_FUT_CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.360
MESU19_FUT_CME [C][M] Weekly #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.360
ESU19_FUT_CME[M] Delta 200v #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.360
ESU19_FUT_CME [C][M] Daily #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2019-08-29 08:02:01.360
ESU19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 2019-08-27 08:03:11 | 2019-08-29 08:03:10.506
ESU19_FUT_CME [C][M] 1 Day #2 | StartDateTimeForLoadingOrderFills: 2019-07-29 21:30:00 | 2019-08-29 08:03:10.509
ESU19_FUT_CME [C][M] 2.50 Range #7 | StartDateTimeForLoadingOrderFills: 2019-07-29 21:30:00 | 2019-08-29 08:03:10.526
ESU19_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 2019-08-27 08:03:11 | 2019-08-29 08:03:10.553
MESU19_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:24:00 | 2019-08-29 08:03:10.632
MESU19_FUT_CME[M] 240 Min #5 | StartDateTimeForLoadingOrderFills: 2019-05-06 09:00:00 | 2019-08-29 08:03:10.649
MESU19_FUT_CME[M] 5 Min #7 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:20:00 | 2019-08-29 08:03:10.650
MESU19_FUT_CME[M] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:00:00 | 2019-08-29 08:03:10.651
ESU19_FUT_CME [C][M] 15 Min #1 | StartDateTimeForLoadingOrderFills: 2019-07-29 21:30:00 | 2019-08-29 08:03:10.652
MESU19_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 2019-08-27 08:03:09 | 2019-08-29 08:03:10.744
ESU19_FUT_CME [C][M] Daily #6 | StartDateTimeForLoadingOrderFills: 2016-08-30 00:00:00 | 2019-08-29 08:03:10.840
ESU19_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 08:03:10.893
ESU19_FUT_CME[M] 60 Min #3 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 08:03:10.909
ESU19_FUT_CME[M] #5 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 08:03:11.042
ESU19_FUT_CME[M] 240 Min #4 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 08:03:11.118
ESU19_FUT_CME[M] 5 Min #8 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 08:03:11.157
MESU19_FUT_CME[M] 2.00 Range #1 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:24:36 | 2019-08-29 08:03:11.176
MESU19_FUT_CME[M] 60 Min #2 | StartDateTimeForLoadingOrderFills: 2019-05-06 10:00:00 | 2019-08-29 08:03:11.176
ESU19_FUT_CME[M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:00 | 2019-08-29 08:03:11.177
ESU19_FUT_CME[M] Delta 200v #9 | StartDateTimeForLoadingOrderFills: 2019-04-30 17:00:55 | 2019-08-29 08:03:11.195
ESU19_FUT_CME[M] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2019-07-29 06:00:00 | 2019-08-29 08:03:11.208
MESU19_FUT_CME [C][M] Weekly #4 | StartDateTimeForLoadingOrderFills: 2019-05-01 00:00:00 | 2019-08-29 08:03:11.209
ESU19_FUT_CME[M] Delta 200v #4 | StartDateTimeForLoadingOrderFills: 2019-07-29 06:00:00 | 2019-08-29 08:03:11.209
DTC Client socket (3) | Socket gracefully closed by remote side. | 2019-08-29 08:06:15.943
Connection to the external service has been lost. | 2019-08-29 08:06:15.943
DTC Client socket (3) | Write in progress. Shutdown being delayed. | 2019-08-29 08:06:15.943
SC Futures Order Routing/Data | Disconnected. | 2019-08-29 08:06:15.966
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-29 08:06:15.966
SC Futures Order Routing/Data | Connecting to the server futurestrading5.sierracharts.com. Port 443 | 2019-08-29 08:06:16.961
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2019-08-29 08:06:16.962
DTC Client socket (1) | Connecting to IP: 209.58.163.194. | 2019-08-29 08:06:16.962
SC Futures Order Routing/Data | Connected to server. | 2019-08-29 08:06:18.345
SC Futures Order Routing/Data | Starting socket receive thread. | 2019-08-29 08:06:18.345
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-08-29 08:06:18.345
DTC Client socket (3) | Write has completed. Shutdown being performed. | 2019-08-29 08:06:20.516
DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-08-29 08:06:20.516
DTC Client socket (3) | Closed. | 2019-08-29 08:06:20.516
SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2019-08-29 08:06:21.492
SC Futures Order Routing/Data | Sending logon request message. | 2019-08-29 08:06:21.492
SC Futures Order Routing/Data | Received logon response. | 2019-08-29 08:06:21.821
SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2019-08-29 08:06:21.821
SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2019-08-29 08:06:21.821
SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2019-08-29 08:06:21.821
SC Futures Order Routing/Data | Trading is supported. | 2019-08-29 08:06:21.821
SC Futures Order Routing/Data | Order cancel and replace is supported. | 2019-08-29 08:06:21.821
SC Futures Order Routing/Data | OCO Orders supported. | 2019-08-29 08:06:21.821
SC Futures Order Routing/Data | Bracket Orders supported. | 2019-08-29 08:06:21.821
SC Futures Order Routing/Data | Connected to data and trading server. | 2019-08-29 08:06:21.821
Sierra Chart account data changed. Requesting updated account information. | 2019-08-29 08:10:08.210
HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2. | 2019-08-29 08:10:08.211
HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (3) | Connecting to IP: 46.4.97.170. | 2019-08-29 08:10:08.211
Successfully processed Sierra Chart account data. | 2019-08-29 08:10:09.984
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. | 2019-08-29 08:10:09.984
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Connecting to IP: 46.4.97.203. | 2019-08-29 08:10:09.984
HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close. | 2019-08-29 08:10:10.232
HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. | 2019-08-29 08:10:10.456
HTTPS connection ID:3 to login.sierrachart.com:443 for request ID:3 (3) | Closed. | 2019-08-29 08:10:10.456
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-08-29 08:10:12.577
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-08-29 08:10:12.805
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-08-29 08:10:12.805
Sierra Chart account data changed. Requesting updated account information. | 2019-08-29 08:11:07.358
HTTPS connection ID:4 to login.sierrachart.com:443 for request ID:4 (3) | Creating socket. Using TLS 1.2. | 2019-08-29 08:11:07.359
HTTPS connection ID:4 to login.sierrachart.com:443 for request ID:4 (3) | Connecting to IP: 46.4.97.170. | 2019-08-29 08:11:07.359
Successfully processed Sierra Chart account data. | 2019-08-29 08:11:08.298
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2. | 2019-08-29 08:11:08.298
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Connecting to IP: 46.4.97.203. | 2019-08-29 08:11:08.298
HTTPS connection ID:4 to login.sierrachart.com:443 for request ID:4 (3) | Shutdown started. Waiting for graceful close. | 2019-08-29 08:11:08.566
HTTPS connection ID:4 to login.sierrachart.com:443 for request ID:4 (3) | Socket gracefully closed by remote side. | 2019-08-29 08:11:08.753
HTTPS connection ID:4 to login.sierrachart.com:443 for request ID:4 (3) | Closed. | 2019-08-29 08:11:08.753
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Shutdown started. Waiting for graceful close. | 2019-08-29 08:11:10.481
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Socket gracefully closed by remote side. | 2019-08-29 08:11:10.692
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Closed. | 2019-08-29 08:11:10.692
DTC Client socket (4) | Socket gracefully closed by remote side. | 2019-08-29 08:34:25.045
DTC Client socket (4) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-08-29 08:34:25.046 *
DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-08-29 08:34:25.070
DTC Client socket (4) | Closed. | 2019-08-29 08:34:25.070
SC Data - All Services | Disconnected from the server. | 2019-08-29 08:34:25.071
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2019-08-29 08:34:25.071
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2019-08-29 08:34:27.125
DTC Client socket (2) | Creating socket. | 2019-08-29 08:34:27.126
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2019-08-29 08:34:27.126
SC Data - All Services | Connected to server. | 2019-08-29 08:34:27.351
SC Data - All Services | Starting socket receive thread. | 2019-08-29 08:34:27.351
SC Data - All Services | Sending encoding request to server: Binary VLS | 2019-08-29 08:34:27.351
SC Data - All Services | Setting DTC encoding to Binary VLS | 2019-08-29 08:34:27.650
SC Data - All Services | Sending logon request message. | 2019-08-29 08:34:27.650
SC Data - All Services | Received logon response. | 2019-08-29 08:34:28.345
SC Data - All Services | Server Name: SC Realtime Server. | 2019-08-29 08:34:28.345
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2019-08-29 08:34:28.345
SC Data - All Services | Successfully connected. | 2019-08-29 08:34:28.345
SC Data - All Services | Trading is not supported. | 2019-08-29 08:34:28.345
Intraday data recording state for symbol ESU19_FUT_CME is set to download 'Pending'. | 2019-08-29 08:34:28.346
SC Data - All Services | Restarting real-time data updates for symbol: ESU19_FUT_CME -> ESU19 | 2019-08-29 08:34:28.346
Intraday data recording state for symbol MESU19_FUT_CME is set to download 'Pending'. | 2019-08-29 08:34:28.346
SC Data - All Services | Restarting real-time data updates for symbol: MESU19_FUT_CME -> MESU19 | 2019-08-29 08:34:28.346
HD Request # 9 | Downloading Intraday chart data for ESU19_FUT_CME to the file ESU19_FUT_CME.scid. Service: cme | 2019-08-29 08:34:28.346
HD Request # 9 | Download start date-time: 2019-08-29 08:32:11.000 | 2019-08-29 08:34:28.346
HD Request # 9 | Using server: ds22.sierracharts.com port 10150 | 2019-08-29 08:34:28.347
Socket (3) | Creating socket. | 2019-08-29 08:34:28.347
Socket (3) | Connecting to IP: 208.185.224.129. | 2019-08-29 08:34:28.347
SC Data - All Services | Clearing market depth for ESU19_FUT_CME. | 2019-08-29 08:34:29.094
SC Data - All Services | Received security definition for symbol ESU19_FUT_CME | 2019-08-29 08:34:29.094
SC Data - All Services | Clearing market depth for MESU19_FUT_CME. | 2019-08-29 08:34:30.486
SC Data - All Services | Received security definition for symbol MESU19_FUT_CME | 2019-08-29 08:34:30.486
HD Request # 9 | Setting DTC encoding to Binary VLS | 2019-08-29 08:34:34.771
HD Request # 9 | Sending historical data logon request message. | 2019-08-29 08:34:34.771
HD Request # 9 | Requesting Intraday data. Start date-time: 2019-08-29 08:32:11. Record interval: 0. Symbol: ESU19 | 2019-08-29 08:34:35.379
HD Request # 9 | Decompressing data. | 2019-08-29 08:34:37.128
HD Request # 9 | Receiving Intraday data for ESU19_FUT_CME starting at 2019-08-29 08:32:11 | 2019-08-29 08:34:37.129
HD Request # 9 | Timestamp of first Intraday data file record written: 2019-08-29 08:32:11 | 2019-08-29 08:34:37.131
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-08-29 08:36:08.486
Historical data download thread signaled to stop. | 2019-08-29 08:36:08.495
HD Request # 9 | Received 8470 records from 2019-08-29 08:32:11.000 to 2019-08-29 08:34:32.046 (2.4 minutes) and wrote 8465 records for ESU19_FUT_CME | 2019-08-29 08:36:08.495
Added 849 Time and Sales records to Intraday data file for ESU19_FUT_CME after download. | 2019-08-29 08:36:08.498
HD Request # 9 | Completion time: 1m 40s | 2019-08-29 08:36:08.501
HD Request # 9 | Intraday data download complete for ESU19_FUT_CME. Unique request ID: 8 | 2019-08-29 08:36:08.501
Removed historical data download ID 8 | 2019-08-29 08:36:08.501
Real-time Intraday chart data file updates started for ESU19_FUT_CME | 2019-08-29 08:36:08.501
Intraday chart data file opened for ESU19_FUT_CME | 2019-08-29 08:36:08.501
HD Request # 10 | Downloading Intraday chart data for MESU19_FUT_CME to the file MESU19_FUT_CME.scid. Service: cme | 2019-08-29 08:36:08.524
HD Request # 10 | Download start date-time: 2019-08-29 08:32:11.000 | 2019-08-29 08:36:08.524
HD Request # 10 | Using server: ds21.sierracharts.com port 10149 | 2019-08-29 08:36:08.524
Socket (5) | Creating socket. | 2019-08-29 08:36:08.524
Socket (5) | Connecting to IP: 216.1.90.129. | 2019-08-29 08:36:08.524
Socket (3) | Socket gracefully closed by remote side. | 2019-08-29 08:36:08.700
Socket (3) | Closed. | 2019-08-29 08:36:08.700
HD Request # 10 | Setting DTC encoding to Binary VLS | 2019-08-29 08:36:08.969
HD Request # 10 | Sending historical data logon request message. | 2019-08-29 08:36:08.969
HD Request # 10 | Requesting Intraday data. Start date-time: 2019-08-29 08:32:11. Record interval: 0. Symbol: MESU19 | 2019-08-29 08:36:09.646
HD Request # 10 | Decompressing data. | 2019-08-29 08:36:09.868
HD Request # 10 | Receiving Intraday data for MESU19_FUT_CME starting at 2019-08-29 08:32:11 | 2019-08-29 08:36:10.372
HD Request # 10 | Timestamp of first Intraday data file record written: 2019-08-29 08:32:11 | 2019-08-29 08:36:10.372
Socket (5) | Shutdown started. Waiting for graceful close. | 2019-08-29 08:36:10.606
Historical data download thread signaled to stop. | 2019-08-29 08:36:10.623
HD Request # 10 | Received 2956 records from 2019-08-29 08:32:11.000 to 2019-08-29 08:36:06.003 (3.9 minutes) and wrote 2955 records for MESU19_FUT_CME | 2019-08-29 08:36:10.623
HD Request # 10 | Completion time: 2s | 2019-08-29 08:36:10.627
HD Request # 10 | Intraday data download complete for MESU19_FUT_CME. Unique request ID: 9 | 2019-08-29 08:36:10.627
Removed historical data download ID 9 | 2019-08-29 08:36:10.627
Real-time Intraday chart data file updates started for MESU19_FUT_CME | 2019-08-29 08:36:10.627
Intraday chart data file opened for MESU19_FUT_CME | 2019-08-29 08:36:10.627
Socket (5) | Socket gracefully closed by remote side. | 2019-08-29 08:36:10.828
Socket (5) | Closed. | 2019-08-29 08:36:10.828
Opened cached Intraday file: C:\SierraChart\Data\MESU19_FUT_CME.scid | 2019-08-29 08:36:11.029
Opened cached Intraday file: C:\SierraChart\Data\ESU19_FUT_CME.scid | 2019-08-29 08:36:11.029
DTC Client socket (2) | Close event error. Windows error code 10053: 你的主机中的软件中止了一个已建立的连接。 | 2019-08-29 08:39:38.181 *
DTC Client socket (2) | Socket gracefully closed by remote side. | 2019-08-29 08:39:38.181
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-08-29 08:39:38.206
DTC Client socket (2) | Closed. | 2019-08-29 08:39:38.206
SC Data - All Services | Disconnected from the server. | 2019-08-29 08:39:38.239
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2019-08-29 08:39:38.239
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2019-08-29 08:39:40.230
DTC Client socket (2) | Creating socket. | 2019-08-29 08:39:40.230
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2019-08-29 08:39:40.231
SC Data - All Services | Connected to server. | 2019-08-29 08:39:43.473
SC Data - All Services | Starting socket receive thread. | 2019-08-29 08:39:43.473
SC Data - All Services | Sending encoding request to server: Binary VLS | 2019-08-29 08:39:43.474
SC Data - All Services | Setting DTC encoding to Binary VLS | 2019-08-29 08:39:52.785
SC Data - All Services | Sending logon request message. | 2019-08-29 08:39:52.785
[2019-08-29 14:12:07]
From what country are you connecting from?
To try connecting again select File >> Disconnect and then File >> Connect to Data Feed.
Date Time Of Last Edit: 2019-08-29 14:12:21
[2019-08-30 02:22:02]
I connect to the TT server No.5 in Singapore from China.
[2019-08-30 02:24:23]
But this shows a problem connecting to a server in Chicago:
Since market data does come from Chicago.
Date Time Of Last Edit: 2019-08-30 02:24:36
