Date/Time: Sun, 02 Feb 2025 06:50:37 +0000
SC data question
View Count: 529
[2019-08-29 04:13:50] |
GreegT - Posts: 23 |
Hello, is there a difference between your NASDAQ free historical data and your paid live exchange feed, as far as, intraday data goes, other than the 15min delay? Does it come from the exact same source? Thanks |
[2019-08-29 05:01:59] |
There is no difference. The source is the same.
