Date/Time: Sun, 02 Feb 2025 06:59:22 +0000
Market Depth Historical Graph
View Count: 1003
[2019-08-29 01:27:54]
User523468 - Posts: 27
Hello SC.
Why is my Market Depth Historical Graph study not displaying historical depth quantity values on previous bars?
Please help.
http://www.sierrachart.com/image.php?Image=1567042179800.png
Date Time Of Last Edit: 2019-08-29 01:30:14
[2019-08-29 05:05:55]
This is controlled by this Input setting with that study:
Market Depth Historical Graph: Show Quantity Numbers
Date Time Of Last Edit: 2019-08-29 05:06:00
[2019-08-29 06:21:18]
I have this input set to “Show Quantity Numbers: In Bars and After Last Bar”, but I still get quantity numbers only displayed in the extended last bar on the right side of the chart.
[2019-08-29 07:33:18]
Not sure this would be an issue but how do you have this Input set:
Graph Only Quantities Greater Or Equal To
[2019-08-29 08:23:54]
I did not change that value, it is set to “0”. Should I take a screenshot of the study settings window for you?
[2019-08-29 08:53:36]
User907968 - Posts: 825
Did you try using a smaller font or increasing the bar spacing?
[2019-08-29 09:03:49]
Yes that's a good point, increase the chart bar spacing significantly and see if you see the numbers.
[2019-08-29 10:06:50]
Thank you guys, after increasing the chart bar spacing, I can now see the value quantities. 🙂
